Challenger 2000 Continuous Beeping
bburns978
I got a 2002 Challenger 2000 with the 240 EFI. I will be driving along at idle speed and as soon as i hit a small wake from another boat the oil light will go on and begin beeping. When I am at cruising speed the same beeping will happen consistently until i make semi-hard maneuvers and it will shut back off until i straighten out again. Also, the beeping stops if i sit on the edge of the boat with the weight on one side at idle speeds. My oil tank is almost at the full line and the engine mounted tank looks fine. I get plenty of blue smoke and water is flowing out the little hole in the hull at the back of the boat.
Please help with any input!
i think i fixed the problem- i topped off the the engine mounted oil resevior and jiggled the sensor around - its good for now thanks
