Finally got the boat back after 2.5months.... Long story short, had a friend that works on skis and boats take it and rebuild carbs, replace fuel pump, do regular maintenance, wear rings, etc....
So today I get it on the water, carbs need adjustment for sure, as the motors will not idle unless I move throttle up,, which makes it a huge hassle to shift since it will only shift in the idle position. So we take off from the dock and notice right away the throttle levers are not synced at all, no biggie, then notice starboard engine won't rev passed 5000rpm, while port engine revs right up to 7000 with almost no throttle input from the lever. So we are basically limping around, one engine seemed to do all the work(port engine). We turned back around and I noticed I had to have the wheel at full lock to keep the boat going straight. Fast forward to the dock, getting ready to trailer the boat, I have almost no control of the boat, between the steering and the idle issue I couldn't do much, so we tied a rope and basically pulled the boat to the trailer. Get it out of water and notice reverse gate linkage isn't bolted up, and steering linkage nut is almost falling off. I put some stainless hardware on the reverse gate link and tightened up the nut on the steering linkage.
Both engines have good compression and new spark plugs.
Here are the cliff notes.
1. Neither engine will idle, is this just a cable adjustment issue?
2. Engines are not synced at throttle control. Also an adjustment?
3. Port engine seemed to freely rev and surge with minimal throttle input. Could this be because the reverse gate was freely floating up and down, not bolted to the starboard side? Or something else?
4. Starboard engine would not rev passed 5k rpm. Carb adjustment?
Thank you in advance.
