jscheibmeir
Looking for some help with a problem that's driving me crazy. I recently cleaned the rave valves and replaced the diaphragm and filter in the carbs. Both engines will start fine and idle fine; even mid range is good but when I push both to WOT they both will go up to 7000 sometimes but the left engine will fall off to 5000 RPM especially under a load. For instance if I turn and it does it out of the hole too but I can get it to go back up to 7000 RPM with the right engine by pulling the throttle levers back and then slamming them forward again. But will drop off again as soon as there is load on it.
Has anybody ever had this problem?
