Challenger 1800 no spark
Yeyin93
Just bought a 2000 challenger has the 210 hp v6 the lady I bought it from said it ran but it was hard to start I would assume it sat for a few years before I bought it Now I’m getting into it trying to get it started. I’m only getting spark on the port side 3 cylinders What should I look for any help is appreciated
Check resistance on trigger base wire pairs. (Easy)
Physically swap at least one ign. coil to the other side. Is port side still sparking on all 3? If yes- you may have a bad control module. The black box on top of the engine with lots of wires. Before declaring a component dead, unplug, inspect, replug all connectors you can reach on the engine. All conductors in the plugs should be clean. No green corrosion allowed.
