S sstorti Member Apr 4, 2016 #1 In the past my challenger would average 186-90 degrees, now at 6000 rpm I am at 205 degrees. Any idea what could have happened?
rcguy Active Member Apr 4, 2016 #3 sstorti said: In the past my challenger would average 186-90 degrees, now at 6000 rpm I am at 205 degrees. Any idea what could have happened? Click to expand... Check out cooling system. Temp gauge sensor replacement.
JPass Well-Known Member Apr 4, 2016 #4 If you have an IR thermometer, you might try taking the temp with it where the sensor is located to confirm the sensor is reading correct.
