Here's the deal, when accelerating boat will go great to about 10-15 mph then cavitate to about 18-20 mph, and I can back off a little and it hooks back up then great to 45+ mph. Most is on port side. The carbon seal is new and not leaking much water at all. When bilge is open we can see very minimal water leaking in and boot is all within manual specs. I'm thinking its probably the from neoprene seal cuz it was replaced this winter and I just reused it. Probably should have replaced it.
What do you think? Make sense?
Also my wear rings are new but I notice on bottom end there is about 2 mm of clearance. Almost double the rest and does not matter what position impeller is in so its not that. Almost like pump is out of round. Could this be culprit?
Thanks for help guys. On vacation and trying to sort out.
