FloorStreet
So we took the boat out, mostly wakeboarded all day, everything working fine.
At the end of the day when we whip it around to go home, I notice that when I leave the steering wheel, it doesn't go straight, it veers right. So I take a look at the RPM's and notice that the left engine is doing about 7000 whereas the right engine is only doing 2000 or 3000.
so I stop, take off again, and at first both engines go up at a constant RPM but within a few seconds the right engine goes back down to 3000.
I don't think this is considered Cavitation (from my understanding thats high rpms with no work)
So what is this called and what could the problem be?
Some things to note:
-probably 6 engine hours prior we sucked up a tow rope on this particular engine/impellar side. I cut off most of it (leaving a tiny bit melted on the impellar shaft) Although its been working fine since then, maybe things loosened up in there eventually?
-the engine itself sounds normal
-there were quite a bit of weeds that day and I think some were getting sucked up but would that cause this problem? Wouldn't weeds cause more of a caviation type problem? Maybe we should put it back in the water to see if it works right now that its cleaned?
So anyway, I'm thinking its something to do with the impellar, wear ring, or shaft right? Or is there a chance that just weeds/vegetations alone would cause something like this?
Thankfully, this happened right around the 10 hour mark so we're taking it in to the dealer anyway, but I would like to be aware of the possible reasons for this issue.
