Kenrussell3
Briefly, 1997 Speedster with twin Rotax 717. My first boat, purchased last fall. Seemed to be running fine. Oil light came on. Left engine running fine. Right engine died, sputtered trying to restart, and died without being able to restart since. Used the right engine to return to the boat ramp. Right engine still will not start. Checked compression. Right engine: seems to start and run fine with 80 psi at both cylinders. Left engine: will not start with 70 psi in front and 20 psi in rear. What is the usual cause of low compression? What do I look for now? Should I do the top end for both engines?
