yamahaman101
Ok now that I have compression at 120 psi in each cylinder can someone tell me how the set screws work? If I turn the low set screw in does it feed less fuel and bog it down and if I turn the screw out is speeds up the idle? Also what is the purpose of the high screw? Air intake? If so how should I set this one?
