Carborator Removal Help needed
yamahaman101
I was wondering if anyone has removed a dual carb off of a 1993 GTX as I can't seam to get to the bottom two bolt nuts. Am I doing something wrong as the carb detail removal does not explain this? Please help---
they need to be loosened and pull up on the carb to loosen them the rest of the way.
It takes finesse with a 13 mm wrench, and helps if you have a few with different angles on them. or a SHORTY 13 mm... (about 2 inches long.)
