I've been enjoying my boat for some time now, but have been trying to chase down a large cavitation issue. I've rebuilt the pumps, changed the props, resealed the units to the boat, etc. As I had ruled out all the 'cheap' and easy stuff, I finally I decided to replace the carbon ring assemblies as some other members had mentioned it but I thought mine looked OK.
I ordered the HD assembly and new bellows from Dominic. While I had some technical problems with the units, Dominic was top notch for help/support. I will be using him again for future parts needs. I'd also recommend replacing the bellows as they are what's putting the pressure on the carbon ring. After 10 years of service, they weren't letting water in but had gotten hard.
The result? Amazing! The boat now shoots out of the hole. No more throttle up and listen to the engines rev while going no where! While cruising, there's no trail of aerated water behind the boat (Yes, the wake is still there
) Everything is just running the way it should now
I read many owners coming back with the same cavitation problems/questions. Please have a look at the carbon seals and think about replacing them. They might look OK and usable as mine did, but they're really just letting air in.
Hope this helps someone.
