Gasngo
Ok I have read things about a carbon ring and carbon seal. Ill assume the ring is in the impeller housing and the seal is behind the PTO clamped to the bellows. That being said fit and finish is the ?. The hat as I read somewhere sits against the carbon seal. Ill assume again that the hat contact to the seal should be centered and even pressure or surface contact. It looks like I could put some fender washers under the rear motor mounts and raise the rear of the motor slightly for a full even contact and center. How important is this?
