If your exhaust pipe is getting how you're not flowing enough cooling water through it. Do you by any chance have a quick connect hose fitting on the line we use flush the skis from the rear? There was one on a 2003 DI and I got a high engine temp warning after about 5 minutes of riding. I remembered seeing that fitting so I removed it and all was well.
On the hot exhaust, remove the hoses and blow through them and through the fittings. I find lots of those are plugged with dirt. Check your Water Control Valve. Good Luck !!
It is a 99 XP 947 that I picked up recently. The engine was exploded by the previous owner so I rebuilt it. Many parts were missing.
The engine runs well, but the issue is
1. the tuned pipe gets very hot after a couple minutes of operation and
2. no water exits on the left side of the hull.
The cylinder and head geta warm, not hot, which is good.
The pressure regulator on the muffler leaked, so I replaced it with a used one. No leaks.
I blew out all of the coolant lines during the process and the engine passed the leak down tests. There is no evidence of water in the combustion chambers.
According to the SD shop manual, most of the water to the tuned pipe comes from the pump, through the head/cylinder and exhaust manifold, then to the pipe. If the engine is cool, then it is getting water. SOME water is directed by the pressure regulator, but very little compared to what comes through the head/engine, so it would seem most of the cooling is done by water coming from the pump.
I tested it using the SD hose adapter which runs the water backwards, so it gets to the pipe first. The pipe was cool.
I made a fitting to insert in the water inlet where the pump bolts to the hull so water would go the way it does when the hull is in the water; results were engine and pipe were cool. Lake test was same as usual, pipe hot, engine cool.
I just found the oring that fits between the pump and the hull was missing. see photo. Could that oring cause the system to work well enough to cool the engine but well enough to cool the pipe?
Also, I have a bronze pump and a plastic one. The holes on the plastic pump are larger. I doubt that would effect anything, but...
Your thoughts?
Thank you!
