Guest_User
Please feel free to add content:
1998 Challenger 1800
carb model: Mikuni Diaphragm BN-40i-38 with accelerator pump
I have been told that these NEW 40mm Mikuni replacements from WSS can be used with little modification on the 98 challenger 1800. I`m just guessing that it is the fuel lines orientation as those carbs have the fuel pumps attached. I have just a fuel supply end plate and no pump on the MAG carbs... These are listed for the 97 and 99 model year but NOT the 98 1800.
http://www.watercraftsuperstore.net/PWC-Caburetors-Carbs/714HP002.html
specs:
MAG side carb has the following:
Low jet 67.5
Hi jet 140
needle valve 1.5
arm spring 95 gram
low speed screw set at 1.25turn out
hi speed closed
http://www.watercraftsuperstore.net/PWC-Caburetors-Carbs/714HP003.html
specs:
PTO side carb has the following:
Low jet 67.5
Hi jet 142.5
needle valve 1.5
arm spring 95 gram
hi speed closed
Accelerator pump added to PTO carb
The specs from the OEM carbs from the shop service manual:
Main jet MAG: 142.5 PTO: 145
Pilot jet 67.5
Adjustment Low-speed 1-1/2 turn ± 1/4
High-speed screw 0
To make these replacement carbs work is it just a simple jetting change to the factory specs?
I can deal with the fuel supply changes by reusing my fuel supply end plates/caps, and removing the pumps on the carb body`s. ( I have remote fuel pumps).
Please educate me in these Mikuni carbs. I don not know what can be interchanged within the same model carb.
Thank you...PR...
specs:
Low jet 67.5
Hi jet 140
needle valve 1.5
arm spring 95 gram
hi speed closed
specs:
Low jet 67.5
Hi jet 142.5
needle valve 1.5
arm spring 95 gram
hi speed closed
Pilot jet 67.5
High-speed screw 0
Thank you...PR...
