Stripped the heads on the carb screws when I went to inspect the internal filters. Does anyone know the screw size? I've searched and can't find the answer. Thanks, Dan.
Long pump bolt: 32mm
short bolt, for the cover: 18mm
Regulator side: 11mm
As far as the kit that OCOD linked... I don't like the hex bolt for the jet block. That will strip easier than a Philips head. besides... if you use the right tool, they don't strip.
