I am in the process of rebuilding the carbs on my 95 speedster (twin 657x fitted with dual carbs which I think are 38's)
First of all, I am using the SBT rebuild kits, I have reused the original spring and arm for the needle valve assy as it seemed better than the SBT replacement, has anyone used the SBT kits at all and do you have an advise to offer on them?
My other question is regarding the needle valve assembly adjustment, when placing a straight edge on the arm should it be perfectly level and applying pressure onto the needle valve? When level mine is not lifting the valve at all but is not pressing the valve either it's half way between hitting the lifting arm and pressing the needle valve which I am assuming is incorrect?
I have checked the pop off and with my bike pump it says it's about 20 psi which according to the manual should be no more than 21psi however this was done with the cover and diaphragm off the carb.
Many thanks
Andy
Many thanks
Andy
