Hi guys, I took off the carbs to clean them on my 98 speedster with twin 787's. After re-installing the carbs and hooking up the cables the cable with the rod that hooks up the top butterflies doesn't reach the set screw. When I took it off the cable was sticking out past the the set screw about half an inch. I don't remember if the butterfly was straight or not. I'll attach a picture, maybe you guys know if that butterfly should be straight up or slightly closed so I can hook up the cable.
Thanks,
Justin
Thanks,
Justin
