Hey guys here's my problem. I have a 1996 XP with the 800 motor. I replaced the grey fuel lines, cleaned out the fuel selector, and cleaned the fuel filters inside of the carbs. When I took the carbs off I tried to mess with any of the adjustments on them. Just took them off, cleaned them, and put them back on. I was finally able to put my ski back on the water and started having problems. When I go to start it, it will fire up for a second or two and then die. It seems like it's not getting fuel. Checked the lines and fuel seems to flow with no problems. I was finally able to start it and keep it running for about 5 min. During this time at WOT it felt like I only had it at half throttle, and almost felt like it was bogging. Once I shut it down, and tried to start it again I would start up for a secong and then die back out. I think I might need to adjust the carb? Anyone have any ideas? Sorry about the long post, I just wanted to give as much info as possible. Thank you in advance.
