drxlcarfreak
My engine normally is typically slow to start between trips, usually about a week in between, which I knew when I bought the boat, no biggie, I just run the starter for 5 seconds twice at the dock to refill the bowls and then it'll start up. Recently it has been hard to start with even an hour or two in between starts, which actually left us stranded yesterday because someone left the radio on and was draining the battery. It had enough amperage to run the starter to start a normal engine, but not enough to get it reprimed and died on us. We are getting a jump pack to keep on the boat so that we aren't stranded again, but I want to fix the base problem so I don't have to keep it turning over for an extended time as well. What could the culprit be? Would it make sense to add a primer switch for the fuel pump to hit for a few seconds before starting the engine?
