Cannot find "Settings" on a 2016 GTI SE 155 CLOCK HELP NEEDED!
aces2splash
I'm trying to change my clock time however when I when I press the mode button the only options shown are;
VTS,
Display,
Fuel Consumption,
If I go in to Display it shows the clock
If I hit the set button this will select that Item to appear on the front of screen
It seems as though I cannot enter the clock settings as Settings are never shown.
If anyone out there that can enlighten me on this genus menu scheme please chime in! Thank you!
If you keep pressing the Mode button you should get to one that says "settings " then hit "set" and use up and down to get to clock, hit "set", the display will scroll instructions for how to set the clock.
That's just part of the issue.
If I press the button it only reads
VTS,
Display,
Fuel Consumption,
Then it rolls back around......
According to the manual, it says to do what you are doing..
1. Press the MODE button repeatedly
until SETTINGS is visible in the multifunction
display.
2. Press the UP/DOWN button repeatedly
until CLOCK is visible
3. Press the SET button to enter the
function. CHANGE CLOCK OFFSET
message will be displayed.
4. Press the UP/DOWN button to adjust
the clock to the correct local
time.
5. Press the SET button to save the
setting and return to the main display.
NOTE: The clock uses the GPS signal
to maintain the appropriate time
referenced to Greenwich Mean Time
(GMT). When setting the clock, only
the hour indicationmay be changed.
I can press the mode button all I want and I'll never see the settings area. My display rolls those three items only.
VTS,
Display,
Fuel Consumption,
And YES. I'm using the master key.
