Palm Bay Chuck
I suspect that I have a bad switch box which is causing my engine output to falter when it hits about 4,000 RPM. The 210 HP M2 engine has 2 of these switch boxes. As I understand it, one switch box handles 3 cylinders on one side of the engine and the other switch box handles the other 3.
I purchased a new one, but I'm not sure which of the two installed could be the unit that is failing and I'm wondering, is there a way to test them OFF the engine with a multi-meter? Or is it easier to test them ON the engine?
I've seen some hints about checking cylinder temp after running the engine for a bit to see if one if 1 side of the engine is cool, but to do this test, I'm thinking I'd have to run at high RPM's and right now I'm not near the water.
Any advice on how to test is appreciated. I've been putting off this project fearing that it's beyond me and I bet it's going to be a simple project! Thank you.
