Can anyone help ID this stuff?
sidewayz
Hello all,
Got this stuff from a storage locker and was wondering if someone could help me identify what I have, and possibly what it's worth. I've looked on the motor, and the only thing I found with a possible id number is on the head and reads "rotax 6923 840". Here's a pic of everything that was in there -
Thanks in advance for the help!
Looks like someone was rebuilding a 1999 Seadoo GSX. (or stripped one with a busted hull)
The engine is a Seadoo Rotax 800. (used in a bunch of skis) Does it rotate smooth? If it does... check the comrpession, and post it here.
140mm pump. (also from the GSX)
Lay out the electrical... and I'll tell you what you have. open the black box so we can see in it. Do the same if you have a gray box.
Motor turns over, but I forgot my guage to check compression. Feels good with a redneck thumb check though :thumbsup: I'll put a guage on it in the morning and see what I've got.
Here's a couple more pics of the electrical:
If compression checks out good, any idea on what this stuff might be worth?
Thanks for the help, I really appreciate it!
Looks like your main computer (MPEM) is missing, and the throttle body.
But, if the engine cranks, and has good compression... you can get good $$$ for it.
