Hi I have a 02 speedster w/240efi merc I changed plugs the other day and did a compression ck same time at the end got distracted left key in on postion and left for a while came back to find a buzzer going off continuous and a pump running which was the fuel pump ,after shutting key off the pump continued to run until i shut battery switch off, now the motor won't start and there is no beeps when i turn the key on ,if i leave key in on position for 30 sec or so the alarm starts and the fuel pump starts and pump won't shut off unless i shut battery off, the buzzer will stop if i turn key off or if i pull the lanyard but not the pump, the oil tank on the motor is full of oil , the boat had no issues until this any help is much apperciated
