This is just a little helping hand on what to look out for when buying a used jetski.
Please add to this thread incase I miss something important out.
(1) First of all check out similar ski's advertised for a price.
(2) Ask about its condition.
(3) How many hours has it got on the clock (if applicable)Some dont have.
(4) Check for a hull number.
(5) Has it been data tagged. (some have some dont)
(6) Ask if you can see or test the ski. (There might be a small charge for
this if testing on a lake or in the sea/ocean.)
(7) Ask to hear the engine running, with a garden hose attached.
(8) Look inside the engine compartment for leaks (exhaust cylinder head and
petrol tank)
(9) Look at and check the stearing mechanism ( if its tight or badly worn
It could be costly)
(10) Is it premix (oil mixed with gas/petrol)
(11) Has it been used mostly in saltwater. If yes this will reflect in the overall
asking price and in its condition. (But not a good thing or bad.)
(12) Pull on the engine to see if it has broken engine mounts.
(13) Compression test on both barrels, if you have the equipment to do this.
(14) Ex Rental ski's have probably had there life beaten out of them, and bodged up to keep them making money.
(15) Make sure Ski title and numbers match USA/ Check Data Tag numbers and paper work match the name on the documents UK.
(16) If bought from Ebay, check out the sellers feedback.
(17) Take a torch/flashlight and look into the pump for wear on the impeller.
Please add any important info to this list.
petrol tank)
It could be costly)
