Mercury builds more reliable MARINE Engines than Bombardier!
Yes, more expensive to fix, but breaks down less often.....
Merc has been around for a long time and is #1 in Marine.
Also you will get a quieter ride,
Better Fuel Economy,
with Less oil consumption....
Self draining cooling system so if your late winterizing,
you don't have to worry about freeze damage too!
Year to year comparison, i don,t think so.
in 1994-1998 mercury was offreing a 90HP 3 cylinder sportjet, 120HP 4 cylinder sportjet and 175HP sportjet (1998+)
the 120HP sport jet was barely as fast in a 14' boat than a 85HP rotax.
both 90 and 120HP were VERY loud (yes, i know they were chrysler engines, recycled by Force, then by Mercury. Gaz consumption was high. Lot of powerloss in the drivetrain. Yes, they need less attention than Rotax engines, but they are a lot less powerful for the size. a 787 jet drive weights nothing compared to a 120HP sportjet unit.
as far as the 175, it was faster, but also it was loving gaz, and performed like a 787 engine, maybe a little more.
Then, there's the 200, + series. Very good outboard. In a jetdrive, i don't think a speedster 240 is faster as a 98 with twin 787. Rebuild in a 2.5 or 3 litre merc is very high, a rebuilt in a rotax is cheap. What keeps mercs unit alive is that they don't rev 7000RPM. As far as 4 strokes, Again, BRP started the supercharged game, a small and compact 1.5 liter 3 cylinder engine providing up to 255HP. the big v6 from honda or merc are no match for weight to power ratio. And that 4tec is quite reliable. Self draining cooling is a +. i'll admit.
Think about it, you have 6 wear rings for a rotax unit, for 1 wear ring for a sportjet. The composite jetpump on a rotax unit is corrosion free compared to an aluminum jetpump from a sportjet. Parts are also cheaper, i bought a complete stator assembly for my 787 for 240$. stator assembly for a 175 sportjet (because 90-120 are no longer available) is 875$
if you throw a rod trough your rotax engine, 1200$ and you're done, if you throw a rod trough your mercury unit, you're boat worth nothing because you need 8375$ to put a new engine! Yes, it happens less often in the mercury unit, but IF it happens, good luck.
EDIT : sorry, it's 5000$ for a new engine, 8375 is for a complete sportjet unit.
