Found that side of the burnt piston had a lot of thin black liquid in the case which seems to be mainly gas. The side of the good piston has a small amont of clean oil in the bottom. Can I assume the gas got in there by running the engine after the piston holed?
Should I have done a pressure check before dissassmbling ?
Thanks
Thanks
