95sportster
Kinda mad about this but I finally traced my hard starting issue to the clearance on my rotary valve/cover.
Long story short, one of the bolt holes on the case itself was stripped out so it was not tight at all- the cause for my valve clearance being too high.
I drilled it out and put in a helicoil as a repair but when I tightened it up to spec, the tab itself on the case snapped off. I couldn't believe it. What are my options to fix the tab on the case?
EDIT: this is a 95 Sportster 657X
