BREAK-IN PERIOD ... DI & 4TEC
(715) 848-4957 BRP Bombardier Recreational Products
Your MPEM log can work against you in a break-in warranty issue.
Direct Injection:
a break-in period of 10 hours is required, On NEW ski take to dealer (owners expense)!
vary the engine speed every few minutes, with brief wide open throttle accelerations of up to 15 seconds
prolonged cruising without speed variation should be avoided.
Do not add oil to the fuel in a oil injected machine, if you use the Seadoo full Synthetic there is no need
for break in oil, as the injectors are not designed to run run through them . But, be sure your oil injection
lever is set to the rich mark, which is the one farthest from the spring tip. Be sure you added oil to the
isolated countershaft gear cavity.
After inspection, new oil filter and bleed the system, hold the oil pump cam wide open for the
first 30-40 seconds when you start it.
CAUTION: Continued wide open throttle runs and prolonged cruiseing without speed variations must be avoided,
this can cause engine damage during the break-in period.
4TEC:
To achieve a good break-in, the throttle lever should not be depressed more than 3/4, however, brief acceleration
and speed variations contribute to a good break-in.
Direct Injection:
4TEC:
