I pulled the case halves apart on a 96 782 that I bought as a core(maybe rebuild it)only to find alot of debris like bits of green gasket and to my surprise brass filings!!
Before I pulled it apart it would not rotate 360 degrees,it would stop at about
355 degrees.
After I pulled the case halves..no problem and the big end of the mag rod is kind of scraped up.The rotary gear APPEARS to be ok
The guy that i got it off of said that he replaced a crank bearing,and the motor does turn over smoothly('cause he didn't put the piston rings back on for reassembly!!)There are no dead spots
To all : thanks for the replies on my accell pump posts..I will be looking in to the diaphram issue in the spring(just waiting for the snow to arrive)
Thanks,Greg
355 degrees.
Thanks,Greg
