Bottom end rebuild kit? Is it a reman crankshaft in a used crankcase? If it is seals and bearings for the crankshaft then STAY AWAY, the crankshaft must be pressed apart, rebuild, then trued and welded- not something you can do in your garage. Get a reman crankshaft assembly at that point.
