Bolt Specs
RobaloGator
I'm sure I'm not the first, but here it is. My son sucked up an anchor line which I tried to remove by removing the metal plate under the impellor. I was unsuccesful at removing the plate and forgot (and lost) the six stainless bolts that hold it on. After a day of use, the engine compartment took on water without realizing it and the engine ingested salt water. I acted quickly and had the plugs removed and oiled the cylinders along with having the crankcase suctioned out several times, the oil replaced as well as two filters. The oil is clear and foam free. I still need the bolts to replace the missing ones, but don't know the specs (length, thread count and size). I also don't have a manual. It is a 2007 GTI 4-TEK 130HP. Any help?
Thanks!
Chris
