Should I just get a short block?Yes, and you are also using the wrong oil.
mixing the two could lead to clogging your injection system.Okay thanks .
Good eye .previous owner used some Walmart stuff. Boat came with 7 gallons. But I filled it with seadoo stuff.
I remember those those Bosch Platinum Fours! We actually did a back to back dyno test on them back in the day... An LS1 Trans Am actually made four less HP with those compared to the regular old NGK copper core plugs! Marketing at its finest!I don't believe there are any bad oils out there anymore, just the wrong one for the application. I recommend using the correct oil engineered for the specific purpose though, and highly suspect of marketing strategies.
This is what I bought at seadoo store....yet its blue .its what they said to use.
Although I've only put about 3 hours on it b4 the bolt wiggled loose and fell into valve....
