BN CARB FUEL PUMP EXPERIMENT - Point of Interest Only
Ed Clark
So, one of the features of a "BN" style carburetor is that it includes a built-in fuel pump. (Twin carb set-ups have one fuel pump for both carbs). When we talk about fuel pumps in general, we most often are considering how much pressure the fuel pump will develop. Of course, in any BN application we will want to check that the "pulse" side of the diaphragm will hold vacuum/pressure without leaking indicating the good health or lack thereof of the fuel pump. But, I recently had cause to wonder just how much suction the fuel pump would develop in order to "lift" the fuel to the carbs. So, I ran an experiment that you may or may not be interested in. This post details what I did.
For background I should explain that I own a pair of 1997 Speedster "project boats" that I purchased from different individuals earlier this year. Basically, I wound up with a couple of apparently sound hulls but a "dog's breakfast" collection of 717 engines with questionable parentage. "Speedster #2" has undergone two sea trials, both of which resulted in a valuable learning experience albeit I haven't gotten more than a couple hundred yards from the dock thus far. Back in the shop, the current goal is to change out the port engine with a seemingly more sound one from "inventory."
The OEM configuration for the '97 Speedsters is that each engine is fitted with a single carb (BN-40i w/accelerator pump). The spare I want to use is from a twin carb (BN-38i) application with parentage from only the gods know where. No worries, right? Hey, a 717 is a 717 is a 717, right? So the plan was and is to simply replace the twin carb set-up on the spare engine with the single carb, manifold and rotary valve cover from the OEM configuration. I can testify that this is a simple exchange in practice. BUT...
During the manifold exchange, I did notice one difference between the two engines that caused me to put my thinking cap on. If you are viewing a 717 engine from the right side and facing the carb set-up, you will notice a difference in where the crankcase pulse port fitting is located. On OEM twin carb configurations, the pulse port is on the mag cylinder (far right). This is because the mag-side carb contains the fuel pump and the location of the crankcase pulse fitting will result in the shortest and most direct path of hook-up hose. Conversely, the OEM configuration for the single carb models is just the opposite. Both the crankcase pulse fitting and the fuel pump fitting are located on the PTO cylinder (far left). Incidentally, it can be seen that crankcase has two cast bosses, one each on the mag and the PTO cylinder. The purpose for which is to drill the boss and install the fitting in the most appropriate location related to the carb configuration that the crankcase is intended for.
While it is a simple matter to extend the pulse hose from the mag-side crankcase fitting to the PTO-facing carburetor fitting to convert to the single carb configuration, it does result in about doubling the length of the pulse hose. I theorized that the pressure pulse might be diminished as a result, hence reducing the si-called suction lift capacity of the pump and resulting in fuel starvation.
If a fuel pump is gravity fed, such as one placed in the bottom of a fuel tank, one need not be concerned with suction lift. However, the BN fuel pumps are above the fuel tank so the pump must "suck" the fuel up to the carb. That's where suction lift comes in. So, I devised a scheme to test the suction lift of the carb using the longer pulse hose before going to all the trouble of sticking the engine in the boat only to find out, well, you know what I would find out in that case ....
To explain this as simply as possible, suction lift in this case is the height of a column of gasoline that the suction side of the pump will pull towards the carburetor. It may be measured many ways but I'll use the term "inches of gasoline." I found that my carb would pull 13" of gasoline. Good news (I hope) since the bottom of the fuel tank is less than 13" below the input to the carburetor.
The following are a series of poor quality pictures to show how I ascertained my alleged suction lift number. I apologize in advance for the poor quality of the photos as I was just snapping shots for my own historical work log and didn't intend to publicize the results. Before you see the photo's, you should know the following things:
1. I used the starter only to spin the engine to produce the needed pulse. I did not tach the starter speed, although from past experience I know that an engine needs to be wound up to 600 rpm before it's going to start and I assume the starter was running at least this speed or higher.
2. For this test, it does not matter how far below the fuel pump the source of fuel is. You are only trying to ascertain the height of a column of gasoline the pump will pull as measured from the surface of the fuel. Similarly, it does not matter how far the fuel pick-up tube extends into the tank below the surface of the fuel. Again, the result will be exactly the same - within reason, of course. So, in the following photos, be advised that the measurement is taken from the top of the surface in the gasoline can to the black mark you will see on the hose going to the fuel pump. I put the black mark on the hose to indicate how high the fuel rose in the hose when I was spinning the starter.
Without further ado:
The first two attached photos show the general experimental set-up. The final two photos show how the measurement was taken from the top of the fuel to the "black mark" on the hose.
Interested, by the time I look at the pictures I can’t remember what the description of each picture is. I’m interested to know your findings (in print)
Yeah, with all my prattle and the poor quality of the photos, it was easy to miss. In this particular experiment, the carb raised a column of gasoline that was 13 inches high as measured from the surface of the gasoline in the container. From a practical standpoint, this just means that in theory, the carb could "prime itself" if the bottom of the fuel tank were located no more than 13 inches below the intake port of the fuel pump. Of course, if one were right at the 13 inch distance, it might be dicey as to whether it would prime or not.
Note that the reason the bottom of the gas tank is taken as a reference point is because a carb needs to be able to maintain prime even if on reserve and nearly out of fuel. Also, I didn't run a test with a shorter pulse line to see if the carb would pull an even greater suction. Upon reflection, I don't believe the difference would be significant, but it should be tested to be sure.
I'm happy to report that following my post I installed the engine with a brand new, Mikuni-copy BN-40i carb and in nothing flat it primed itself and started the engine A-OK.
Interesting and good to know for sure. So during the experiment you had the longer pulse line than normal? A fairly rigid pulse line, such as the black automotive fuel line? Or the grey tempo fuel line. Since you have engine in now, it’s to late to test but i an interested to know the number of inches of lift with the shorter pulse line, I’m suspecting it would be a greater draw, also the same tests done in the same engine using the softer clear fuel line that is sold, I’m suspecting that the fuel pump wouldn’t pull as many inches due to the soft line absorbing some of the pulse. Glad you got the motor in and running
During the experiment and upon installation I used the longer, automotive style reinforced fuel line. My suspicions are the same as yours regarding longer vs. shorter pulse lines. Also, I believe a pliable line would likely reduce effectiveness. Regarding clear fuel lines, there's a lot of stuff out there being sold as clear fuel line. However, most of it - not all - is pvc which is totally unsuitable for fuel service (or any other kind of automotive service if you ask me.) Therefore, I don't intend to test anything clear as I don't plan on using it in any case. I may get an opportunity to run the shorter vs longer test in a couple of weeks as I'm building up another spare in the shop. I'll holler if I find out anything new.
The added length isn't going to make a difference on the 720 cases. Some of the models even have a remote mounted fuel pump. The only thing that makes a difference is if you sue a soft hose that can collapse under the pulses.
Google "viscosity relation to piping losses" and read the AI answer. Air isn't very viscous. I do the same sorts of garage experiments and I am very impressed with yours.
It's been 47 years since I graduated from college and all those classes are a distant memory. Now all I know are the basics and I remember them with sayings. My dad was big on sayings and it drove me crazy. My first thought reading your post was, pumps are good at pumping but not at sucking. Otherwise they would be called sucks.
Not to beat a dead horse (but I will anyway). Actually, my theory behind why, if at all, a longer pulse line might have (but apparently didn't) result in less of a pulse pressure is that it adds to the volume of the crankcase. So, the displacing volume of the piston as it is on it's downstroke, is now pressurizing a slightly larger volume. Therefore, theoretically at least, the average pressure pulse would be lower. That being said, I definitely now agree with mikidymac that the effect, if any, is probably immeasurable at least by the typical hack such as myself. At the end of the day, if I'm getting enough suck, as so eloquently elaborated on by Brian, well then game over! I do certainly agree that soft pulse lines are a no no.
