Sfx27 Member Jun 10, 2020 #1 Why on earth would they not send you the tool to install the check valves? Anyone know how to do it without the tool?
mikidymac Moderator Staff member Moderator Jun 11, 2020 #2 Because this is a carb kit and not a tool kit? You can use a couple wraps of dental floss to pull then through. You also need to follow this exactly... Carb Rebuild Thread And check pop-off and leak down so you are going to have to make or buy a pop-off tester.
