Hi,
I am a real newbie and this is the first time i am attempting to fix something myself on my ski.
I had my ski in for repair where they said they replaced the gasket on the exhaust manifold.
I took it out today for the first time and the ski would only accelerate whilst i held the throttle half way, if i attempted to increase the throttle past that point it would make a different noise and not accelerate any faster. It seemed to work the engine more for no acceleration. there also seemed to be an "airy" noise. After a while of full acceleration I could smell fuel like it was flooded and it would run poorly for a while.
When i took it out it was quite full with water and when i took it home and ran it with clean water i noticed water spraying out of the metal tube (which i assume is the exhaust??? does this have water in it) when i accelerated faster more water started spraying out and the gasket popped out further realeasing a stream of water.
Would this cause the problem of the lack of acceleration on the water? is it easy to replace the gasket?
thanks
thanks
