check the obvious first, battery and leads, check both ends(starter and battery). make sure battery is not in backwards.( it happens) if all is good then check and see if there is voltage at the small wire going to the small post on the starter solenoid when pushing the start button. if it does then your soleniod id bad if not it could be the start button,mpem or lanyard switch.
