MobileWaterCraft
Have 2 '99 GTI's Ski "A" blew 5 amp fuse. swapped out ski "B" mpem A ran fine but then blew 5 amp fuse again. moved mpem back to B it too blew the 5 amp. Coincedence????? 2 MPEM's going bad at about the same time? Could there be something causing the fuse to blow other than simply a bad MPEM? What should I look for? Could an over voltage from the regulator cause this? bad stator? bad ground? shorted wire? Help Please. Thanks
