blowing charging fuse
jps601
1800 challenger port engine runs like crap. wont rev up also sounds like it is missing. Came to find out the charging fuse is blown and when I try to replace it, it blows automatically. So I unplugged harness from engine put new fuse in and soon as I plug harness back into engine it blows. Does any one know where my electrical problem may be. Thanks.....
Rectifier/regulator....
Remove the rectifier/regulator from your other engine, dis-connect the one on the engine in question and give it a try.
The fuse is to protect your system from a ground in your magneto or a bad rectifier. So, try replacing the rectifier/regulator with your good motor and see what you get.
That's the benefits of a twin engine model.........:cheers:
switched rectifier
I switched rectifier from good engine still blowing the same fuse. Whats that mean bad magneto?
