Mooze
Well, It happened...
I took the boat out after the rebuild of the number two eng, 96 speedster, and the aft cyl lost compression... DO'H! Come to find out it was just the o-ring! Good, Whew, crisis adverted! Well i bought two new o-rings put 'em in and was out on water next day... Both eng's humming along.... I say to my friend, "Is both weep holes spitting water?" Of course only one was! SHUT DOWN! SHUT DOWN! Open the eng cover, OMG! water every where! What happened? DOUBLE DO'H, facepalm, and every other anecdote you can think of! I forgot to tighten the water input line to the head!
SO POOF goes the number 2 eng fwd cylinder no compression!
So question! the eng is nowhere near perfect... One cylinder has rings fried into the piston! The jug has scared walls... DO I order a whole top end and make it all so perfect? Or do I try to clean up / replace piston and rings in the bad cylinder?!? Also, is SBT's 475$ top end kit worth it or no?
Thats my story and I'm Sticking to it!
This video is from the the first run, and this is where I blew the cylinder O-ring out! I fixed it and then I blew the cylinder! bOOOOOO!!!
https://www.youtube.com/watch?v=YeLgKfPpDy0
