Water sports
Seadoo Speedster 787 2 stroke twin engine jet boat.
Hi
Okay I have installed all my new clear oil pipes and replace both oil pumps I have filled the oil reservoir with oil 1 have removed both oil pumps and there bleed screws. Oil and air is coming out of each oil pump however the lines don't seem to be completely falling up will oil please advise what I should do I have also put a battery drill in reverse on the pump and I have blowing some air by mouth into the oil reservoir From the top oil vent, valve
My understanding once I have all the air
out and the oil piping iand all the lines I then close of the oil bleed screw and open the butterfly on the oil pump fully open and put a drill on the oil pump until I see oil dripping into the manifold from the small pipes.
note i have replaced all oil pipes and oil filters
Hi
