Bmedlin85
I finally got the engine back in the boat and it fires up instantly... Now I am having an issue with the oil system. I replaced all of the oil line and replaced the oil pump. The seadoo manual states to remove the bleeder screw from the pump to bleed any air out so that the line from the oil tank to the pump is full of oil. I removed the screw and the line would not fill with oil. I even manually held the pump open and still not much oil coming from the tank. I could get the line about have way full but that is it. It seems the fittings on the tank may be an issue because it is pretty loose and when I pushed it at at angle the line filled with oil.
Now I am not getting much oil to the injector lines. The seadoo manual states the if the lines do not fill with oil start the engine on a hose and run until the lines are full. I have an issue with this because that means the engine is not getting oil. I removed the spark plugs just to spin the motor over to try to fill the lines that way. After a while of spinning the motor with the pump manually opened the lines are only have way full of oil. I do not want to spin the motor much more since no oil is coming from the injectors.
Am I missing something or could I possibly have a bad pump? And if I had a bad pump would any oil at all get into the lines.
Thanks in advance for any advice.
