Bilge pump
johnathanrn
Hi. 2008 sea doo challenger se supercharged. When I turn the bilge pump on am I supposed to hear it? And where does the water come out? I flipped on the switch but did not see any water or hear any pump working....the engine had no water in it FYI
I'm also wondering where the water is suppose to come out.
Ive pumped water in While on the trailer and haven't seen any water exit anywhere.
It should come from a small hole near the rub rail on the drivers side of your boat around 2/3 feet from the back corner.
correct, and you won't really hear it unless you have the cover open and your head in the engine compartment.
They come on automatically, so you shouldnt even worry about it.
I can hear it working but never see anything coming out anywhere.
I put the hose in there when it was up on trailer and the pump started up automatically but never saw anything exit anywhere.
Could it be clogged.
I'm planning in leaving it in the water over the long weekend this week and wanted to make sure it was working.
If the water is halfway up the pump, it should be coming on. Check the fuse to see if it is blown. There is a float switch in the pump itself and when the water gets to a certain level, that switch turns the pump on. I had a Sportster 4tec and the manual switch did not work for the bilge pump, but it came on automatically if the water ever got too high in there. As long as it comes on automatically, you should not have anything to worry about. You can test this by pouring water into bilge enough to get lower third of pump submerged. You can do this while on the trailer. If the pump is left on and not pumping water, it could burn up and it may need to be replaced. Thankfully, they are pretty cheap, and I would probably upgrade it to a little higher GPH rating, but not too much more as the tubing going outboard is only so big.
