bilge pump
sheffs
I have a 1998 Sea doo GTX limited I had to have the engine rebuilt and since I got the machine back the engine compartment fills up with water when riding it so I am guessing it is the bilge pump that is not working, can anyone help me out with any information on where the pump is located, and any troubleshooting steps I can do to correct this issue.
Thank you
Sheffs
No bilge pump… Check the pump for the siphon tubes
Item # 18 on pump parts drawing.
You should not be getting a lot of water in the hull under normal circumstances. As said above check your bailers.
