I have a 1998 Sportster 1800 with the dual 85HP motors... I noticed that my bilge pump doesn't seem to be working... In the manual I believe it says that the pump should work even with the boat off, when the lanyard is off too. Well, I engaged the lanyard, and I hit the switch, and it doesn't run. I haven't tried it with the boat on, but should it work with it off?
Can I just jump it to the batter real quick to make sure the pump works? Maybe just the switch is bad?
If it is indeed bad, then do I have to buy a specific pump, or can I use a generic one? How many GPH do I need to go? THanks!!
