before I take engine apart
jecord
I posted in the trobleshotting about my 95xp which set for 2 years. When I tryed to start it the starter keep stopping. When I pulled the plugs it seemed like water and oil came out. It seems to be pumping out a lot of oil and I cant get it all out. After reading more I think it might be seals in the lower half of engine which would require crank shaft replacement. I might try to find used parts but would like to know if futher troubleshotting should be done first. Also I need to know how to find out if there is damage from water being left in the engine so I can replace them at the same time. Thanks
John
