LeeZeitvogel
So I ran the boat today in the bay and it did fine, and when I go to flush the engine at the house I hook the hose up turn the water on full blast then crank the engine and only run it at idle speed just like the manual says and like clock work it sounds a constant solid warning beep after about 2 or 3 minutes so I get scared and turn the boat engine off, wait about 5 to 10 minutes and crank it again and 2 minutes into the flush it beeps again. It makes flushing for 10 minutes (like the manual says) a timely procedure, plus am I hurting the engine, and is it perhaps not getting enough water, I don't have a clue why it beeps only when I flush, Any ideas?
