Battery
I just installed an Optima D27M AGM dual purpose starting and deep cycle marine battery in my 99 Sportster 1800, only time will tell if it was a good choice.
Are deep cycle/dual purpose batteries hard for the stators to recharge??
No. BUT, the output of the Rotax engines is relatively low. So, running big batteries will take a while to recharge.
Anytime I set up a full sized battery (or duals) on a Rotax boat... I tell the owner to charge the batteries before any outings. That way, you don't have to worry.
Makes sense, will a battery tender work instead of charging each time?
Yes. And it won't fry the battery in the process. The good ones put a load on the battery once it gets charged and then trickles it back up.
Hello all
want to replace my battery but before i just take mine in to the store to match up i would like to get info for correct battery,not sure if the battery that came with my used 2005 le di is correct, does anyone have specs for correct battery for my boat?local dealer couldn't
tell me
thanks
Optima blue 34M here and an on/off isolator switch. I've got a amp and sub in my boat and I play the hell out of it for hours......no issues so far.
