Battery, Solenoid, Starter??? I hit 'Start' button 3-5 times before it starts.
mlmm2000
My GTX 'clicks' the first 3-5 times I try to start it. The battery checked fine. How do I know if it is the switch, the relay, or the starter??
unplug the wires to the switch and "touch" them. If no go, then "jump" the relay, if no go, then starter or cable from relay to starter are bad/corroded
timmyboy76, I appreciate your help. Just to be clear, to 'jump' the relay, I disconnect the battery cables from the relay and than connect my charger to the relay posts?
nope...leave the red cables hooked to the "post" on the relay. Cable from battery to relay, and cable from relay to starter. Jump the 2-post at relay w/ heavy gauge wire or screwdriver. Be prepared, cause its a "nasty" jump...:reddevil:
