Battery Size
kduv
I have a 2005 GTX. The battery seems to be going bad. What are the size and deminsions I need to be looking for in a replacement battery?
Here are the OEM specs...
Battery Family: YuMicron
Battery Type: YB30CL-B
Voltage: 12
Capacity: 30
Dimensions: 6 5/8" x 5 3/16" x 7 9/16"
Weight: 14.5lbs.
Metric Dimensions: 168mm x 132mm x 192.2mm
MetricWeight: kg
Polarity:
Acid Volume: 57.5
Amps: 3.0
I would suggest going with a Deka Battery replacement. It's sealed and maintenance free. Also weighs 21lbs vs. OEM 14.5lbs. 375CCA's. I recently purchased one for $79.99 at local battery dealer.
Thanks GTX185. I'm searching out a local dealer for the Deka. I really appreciate the quick response.
