battery not charging
Regulator/rectifier....
How do you know that battery is not charging? Did you check it with a volt meter.
If you have a hot battery and start it and then check the battery with your probes and it's showing 12.? volts, then your rectifier/regulator is shot. You can find this part at the top of the page in our parts section. It's a simple fix and not really expensive................:cheers:
